Texasbill
Oct 27, 2019Aspirant
Getting error 404 on some websites
Hi, I use a Netgear Nighthawk M1 connected to the ATT network. I use it as a stand-alone hotspot when I travel and at my home connected by Ethernet to my Orbi system. It was working perfectly at ...
Oct 29, 2019Guru - Experienced User
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-c
- TexasbillOct 29, 2019AspirantThis Netgear Nighthawk M1 can be put in bridge mode and was working perfectly until I went on vacation and turned the Wi-Fi back on to use the Nighthawk as a stand-alone device. I believe it is in bridge mode now as well.
- FURRYe38Oct 29, 2019Guru - Experienced User
There is too many private IP addressed hops between the RBR and your ISP service. Why your having issues getting to web site resources. Need a public IP address ##.##.###.### at the WAN port of the RBR if possible.
Need to make sure the M1 is fully bridged.
