Texasbill
Oct 28, 2019Aspirant
Getting error 404 on some websites
Hi, I use a Netgear Nighthawk M1 connected to the ATT network. I use it as a stand-alone hotspot when I travel and at my home connected by Ethernet to my Orbi system. It was working perfectly at ...
Texasbill
Oct 29, 2019Aspirant
Here is what I get:
traceroute to 8.8.8.8 (8.8.8.8), 64 hops max, 52 byte packets
1 10.0.0.1 (10.0.0.1) 4.380 ms 3.041 ms 3.656 ms
2 10.78.87.1 (10.78.87.1) 4.760 ms 5.953 ms 4.382 ms
3 172.26.96.161 (172.26.96.161) 210.314 ms 228.399 ms 197.444 ms
4 172.17.32.60 (172.17.32.60) 320.297 ms 530.741 ms 339.404 ms
5 12.249.2.1 (12.249.2.1) 407.724 ms 274.091 ms 292.604 ms
DNS:
DNS Server 172.26.38.1
Type DHCP
I appreciate your help!
6 12.83.179.194 (12.83.179.194) 395.193 ms 283.434 ms 263.141 ms
7 12.122.85.193 (12.122.85.193) 282.772 ms 224.399 ms 265.629 ms
8 206.121.120.90 (206.121.120.90) 296.069 ms
206.121.120.86 (206.121.120.86) 360.121 ms
206.121.120.90 (206.121.120.90) 240.633 ms
ekhalil
Oct 29, 2019Master
Texasbill wrote:Here is what I get:
Very strange that the first 4 hops are private IP addresses! I think the 10.0.0.1 is Orbi's gateway IP address, I wonder what the 10.78.87.1 is? Can it be the Nighthawk's way out?
Can you please connect a computer to Nighthawk directly and make the same traceroute command.
Also, have you tried to change the DNS IP address in the web GUI under >> ADVANCED >> Setup >> Internet Setup >> to "Use these DNS Servers and try 8.8.8.8 as primary and 8.8.4.4 as secondary and see if you will get any improvement.
