Texasbill
Oct 28, 2019Aspirant
Getting error 404 on some websites
Hi, I use a Netgear Nighthawk M1 connected to the ATT network. I use it as a stand-alone hotspot when I travel and at my home connected by Ethernet to my Orbi system. It was working perfectly at ...
ekhalil
Oct 28, 2019Master
1. Just to confirm, can you please open a Command Prompt on any computer attached to Orbi and type:
> tracert 8.8.8.8 (or traceroute 8.8.8.8 if you're using a Mac computer)
What will be the first two hops?
2. What is the setting of the DNS configuration in Orbi? This issue can very well be caused by the DNS configuration. Try different settings (e.g. try 8.8.8.8 as DNS) and see if things improve.
Texasbill
Oct 30, 2019Aspirant
I used the 8.8.8.8 as you suggested and it seemed to work. I have been able to get on websites that previously gave me a 404 error. I’m just not sure why this worked as I never touched the Orbi settings. I just removed the Nighthawk to take with me on vacation. I just assumed that I could plug it back in and put it in bridge mode? Could removing the Nighthawk have changed the DNS? In any case....thank you!
