randerton
Oct 20, 2018Aspirant
Getting ORBI to work with Roomba
I just purchased a robotic vacuum and it turns out it will only connect to 2.4 MHz networks. The latest firmware for my Orbi will not allow selection of 2.4 vs. 5.0 SSID's. I am aware there are sop...
Oct 20, 2018Guru - Experienced User
What FW is currently loaded?
What security mode are you using? Try open first to see if the device will connect. The try WPA and test. Then try WPA2 and AES only.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Hoping NG support can have a look at this. So try this out as well.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
