SHANNONSUPER
Sep 21, 2019Follower
Getting wifi speeds of 400Mbps but only getting 70Mbps ehternet
It's just so wierd that I can get almost 500Mbps on my phone wifi but only 70Mbps on my PlayStation pro.
Hows is the game console connected? Wireless or wired? Wired is preferred
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
