ZipFunk
Apr 03, 2023Aspirant
Getting wifi to outbuilding
First off, I apologize if this is the wrong forum for my question. I have the Orbi Tri-Band Whole Home Mesh (RBK23) In the house the wifi is great. I have a few devices that cant get reliable wifi ...
- Apr 03, 2023
Distances would be too far.
Either a ethernet CAT6A STP cable would or or maybe a wireless point to point bridge would work:
ZipFunk
Thanks for the quick reply.
I figured the best bet was to trench a cable to the outbuildings and then I'm assuming hook it up to another orbi satellite when it gets there?
Apr 03, 2023Guru - Experienced User
Yes. That would be recommended. Then you can connect a RBS out there via ethernet:
