bobselff
Oct 20, 2019Aspirant
Gigabit internet
I have gigablast internet connected to the WAN port. When I run a speed test with the orbi app I'm only show 400 to 500 mbps. Does the Orbi not support gig WAN?
bobselff
Oct 21, 2019Aspirant
Cox ISP
Netgear Nighthawk cm1100 modem
Orbi RBR50
Firmware v2.5.0.38
Speed test: (speakeasy.net)
Wireless: 437Mbps
Wired: 590Mbps
Orbi RBR50
Firmware v2.5.0.38
Wireless: 437Mbps
Wired: 590Mbps
Oct 21, 2019Guru - Experienced User
What are you speeds with a wired PC connected to the CM modem directly?
- bobselffOct 27, 2019AspirantConnected directly to modem and getting these speeds:
Cox internet test: 801Mbps
Speakeasy test: 401Mbps- FURRYe38Oct 27, 2019Guru - Experienced User
Have you factory reset the RBR with a wired PC connected to the RBR only. Power OFF the modem for 30 seconds then back on. Then skip the setup wizard and get to the RBRs web page. Log out of the web page. Then run a speedtest with ooklas installable speed test app on the wired PC?
You can do a back up configuration to file of the RBR before factory resettting so you can load your configuration back on after trying this reset and speed test process.
Possible your unit maybe effect by the HW NAT accelleration not working on your unit.
