Blair2201
Jun 19, 2020Tutor
Gigabit line now operating at 10/100!!
Hi I have a RBR40 which runs a hard line (Cat6) to a D-Link DGS-108 switch (about 4 metres) which then runs another hard line (8-10 mtrs) to my RBS40 which located in my garden office. The cabl...
Blair2201
Jun 19, 2020Tutor
I've done some more research and found that the installation engineer has installed CCA Cat 6 cable - it may have been damaged during installation causing the lowering of speed. But as the line has run over 300mbps it does beg the question whether there is something else at fault.
Any help would be appreciated.
Jun 19, 2020Guru - Experienced User
Have you tried a different switch?
