jhandy
Jan 10, 2020Aspirant
Glad I left the old system up
When using the Orbi network and trying to get access to a email link or any other link I get error code 401(not found). when I switch back to the old system no problem. If its bit defender, how do I...
Jan 10, 2020Guru - Experienced User
Which orbi system?
What firmware are you running?
What modem are you connected to?
Have you just setup this system (aka is it new)?
Are you able to access the gui via a browser?
You can go to netgear.com/support/ type in your actual model number and have access to troubleshooting, install manuals, install videos, the actual manual. Its a great resource if you're just setting up the system.
If its new, you also have access to 90 days of free support. You'd click mynetgear at the top of the page here, register an account, then your device, and from there you can access support.
- jhandyJan 11, 2020Aspirant
It's new registered 1/2/20 and is a RBR50. It's connected to a Netgear AC1750 modem. It's a router motem combo and it still works fine.
The orbi must be blocking thus getting error code 401 or page not found. When I switch back to my old system all works fine.
- plemansJan 11, 2020Guru - Experienced User
jhandy wrote:It's new registered 1/2/20 and is a RBR50. It's connected to a Netgear AC1750 modem. It's a router motem combo and it still works fine.
Netgear ac1750 is a speed not a model number.
Regardless, if you're using a modem router combo and an orbi and the orbi is running in router mode, you're in a double nat which can give you the error your getting.
https://kb.netgear.com/30186/What-is-Double-NAT
your 2 easiest options are to place the combo device in modem only mode or to place the orbi in AP mode.
