BrianB111's avatar
BrianB111
Initiate
Nov 16, 2018
Go Back to OPENDNS Parental Controls
I enabled and tried Disney Circle but it caused many issues so I removed it. I want to go back to OPENDNS parental controls but now when I hit the Parental controls in the App it just goes to a screen showing Disney Circles disabled.
How can I move back to the OpenDNS parental controls??
  • BrianB111 wrote:
    ...when I hit the Parental controls in the App it just goes to a screen showing Disney Circles disabled.
    Please use the web interface (orbilogin.net) and not the app. Please see below:
  • FURRYe38's avatar
    Try a factory reset on the Orbi router and setup from scratch...
    • JammasterC's avatar
      JammasterC
      Star
      Basic / Internet / DNS
      208.67.222.123
      208.67.220.123
      are the OpenDNS FamilySheild nameservers
    • BrianB111's avatar
      BrianB111
      Initiate
      UHere's the answer - it is not possible throught the Android App, I needed to do it via a computer interface.
      Thanks to the person that recommended that.
