Walleye13
Jul 10, 2019Aspirant
Good bandwidth at the router not so good at the device, 25mbps at router, 10mbps at the device
I have an RBR50, firmware is 2.3.1.60 with 2 satellites, my internet connection is a 25mbps down and 5 mbps up. When i run a speed test at the router i show the proper speeds, but when i run a test f...
Jul 10, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What devices are you using for wireless speed tests?
Do wired PC speed test the same?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Walleye13Jul 12, 2019Aspirant
Sensei, i have addressed all of your suggestions, it seems everytime i try one of your recommend settings it preforms slower.
As i said initially i can get 25mbps at the router. (when i go to the QOS setting it allows me to run a speed test) when i run the speed test i get the proper speeds. This also applies to plugging directly into the router. When i try my laptop wirelessly i only get 10mbps, with the laptop plugged into the satellite i only get 10meg.
The satellites are approx 30 ft from the router +/- a couple feet.
Still looking for a solution.
- FURRYe38Jul 12, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?What devices are you using for wireless speed tests?
Has a factory reset been performed on the RBR, setup from scratch and test with both wired and wireless devices with the RBR while the RBS is turned OFF?
- CrimpOnJul 12, 2019Guru - Experienced User
Could you provide a couple of information items:
What specific laptop is being used for the tests?
Can you please capture the backhaul information. i.e. connect to the Orbi web interface, replace "index.htm" with "debug.htm". When the debug page comes up, check the box "Enable Telnet". Then... use a telnet program to connect to the Orbi, enter "admin" and the administrative password, and then type "satelliteinfo wifi" (no quotes). On my Orbi RBR50, this is what I get:
"mac address" : "A0:04:60:0D:96:FA",
"hop" : "1",
"bridge mac" : "A0:04:60:0D:96:FA",
"backhaul conntype" : "5GHz",
"backhaul rssi" : "-71",
"backhaul macaddress" : "A0:04:60:0D:96:FD",
"backhaul phytxrate" : "780",
"backhaul phyrxrate" : "780",
"backhaul parentmac" : "A0:04:60:1C:02:39"This indicates that my (one) satellite is "1 hop" from the router (which is has to be, there being no more satellites) and that the transmit and receive rates on the backhaul are 780mb.
