GloryUprising
Dec 11, 2017Aspirant
Google Home and Chromecast
So I got the super orbi crashing and rebooting on the router and satellites. I seemed to have narrowed it down to when working with Google Home. When ever I try to stream something it would pr...
DarrenM
Dec 13, 2017Sr. NETGEAR Moderator
Hello GloryUprising
Have you tried a factory reset of orbi since updating the firmware?
DarrenM
- GloryUprisingDec 13, 2017Aspirant
Yes.
Factory restarted via webinterface and pin hole in back.
Also telneted and cleared NVRAM as well.
Still rebooting.
- mccxDec 13, 2017Star
Any useful suggestion/fix other than factory resets?
- DarrenMDec 14, 2017Sr. NETGEAR Moderator
I suggest you contact support and work with them on the orbi rebooting issues they will be able to replace the unit if needed.
http://www.netgear.com/support/contact.aspx
DarrenM
