GloryUprising
Dec 11, 2017Aspirant
Google Home and Chromecast
So I got the super orbi crashing and rebooting on the router and satellites. I seemed to have narrowed it down to when working with Google Home. When ever I try to stream something it would pr...
DarrenM
Dec 13, 2017Sr. NETGEAR Moderator
Hello GloryUprising
Have you tried a factory reset of orbi since updating the firmware?
DarrenM
GloryUprising
Dec 13, 2017Aspirant
Yes.
Factory restarted via webinterface and pin hole in back.
Also telneted and cleared NVRAM as well.
Still rebooting.
- mccxDec 13, 2017Star
Any useful suggestion/fix other than factory resets?
- DarrenMDec 14, 2017Sr. NETGEAR Moderator
I suggest you contact support and work with them on the orbi rebooting issues they will be able to replace the unit if needed.
http://www.netgear.com/support/contact.aspx
DarrenM
