GloryUprising
Dec 11, 2017Aspirant
Google Home and Chromecast
So I got the super orbi crashing and rebooting on the router and satellites. I seemed to have narrowed it down to when working with Google Home. When ever I try to stream something it would pr...
GloryUprising
Dec 13, 2017Aspirant
Yes.
Factory restarted via webinterface and pin hole in back.
Also telneted and cleared NVRAM as well.
Still rebooting.
DarrenM
Dec 14, 2017Sr. NETGEAR Moderator
I suggest you contact support and work with them on the orbi rebooting issues they will be able to replace the unit if needed.
http://www.netgear.com/support/contact.aspx
DarrenM
