yayafreckles
Jun 15, 2019Aspirant
Google Home Hub connectivity to Orbi RBR40 Access Point
We have an Orbi RBR40 mesh system as an Access Point through our Verizon Gateway Router. We purchased a Google Home Hub (now called a Google Nest Hub) and cannot even set up the Hub as it refuses to ...
- Jun 17, 2019You should only select the network which you phone is connected to.
There can be some conflicting information stored in your nest hub. Please try to factory reset the nest hub and try again.
yayafreckles
Jun 16, 2019Aspirant
Thanks for the reply. So I ran a traceroute as you instructed but because I'm not the most tech saavy I don't know what im looking at. The results list "traceroute to 8.8.8.8 (8.8.8.8), 64 hops max, 72 byte packets" then goes on to list numbers 1-8, each number has a different description or numerical value. Any addtional guidance for me?
ekhalil
Jun 16, 2019Master
yayafreckles wrote:Thanks for the reply. So I ran a traceroute as you instructed but because I'm not the most tech saavy I don't know what im looking at. The results list "traceroute to 8.8.8.8 (8.8.8.8), 64 hops max, 72 byte packets" then goes on to list numbers 1-8, each number has a different description or numerical value. Any addtional guidance for me?
Correct, you will get a list of hops. What IP addresses do you have in the first 2 hops/lines in the list. Are they in the form 192.168.1.x (private IP addresses) or something else?
- yayafrecklesJun 16, 2019Aspirant
The first line does have that number you listed with fios_quantum_gateway. The second and third line is just a collection of numbers with no words. Lines 4 and 5 mention my internet provider. Its not until line 8 that it says google_public-dns-a.google.com (8.8.8.8)
- ekhalilJun 16, 2019Master
yayafreckles wrote:The first line does have that number you listed with fios_quantum_gateway. The second and third line is just a collection of numbers with no words. Lines 4 and 5 mention my internet provider. Its not until line 8 that it says google_public-dns-a.google.com (8.8.8.8)
What are the first few digits in the IP address in the second line please?
47.14
