yayafreckles
Jun 16, 2019Aspirant
Google Home Hub connectivity to Orbi RBR40 Access Point
We have an Orbi RBR40 mesh system as an Access Point through our Verizon Gateway Router. We purchased a Google Home Hub (now called a Google Nest Hub) and cannot even set up the Hub as it refuses to ...
- Jun 17, 2019You should only select the network which you phone is connected to.
There can be some conflicting information stored in your nest hub. Please try to factory reset the nest hub and try again.
ekhalil
Jun 16, 2019Master
yayafreckles wrote:The first line does have that number you listed with fios_quantum_gateway. The second and third line is just a collection of numbers with no words. Lines 4 and 5 mention my internet provider. Its not until line 8 that it says google_public-dns-a.google.com (8.8.8.8)
What are the first few digits in the IP address in the second line please?
yayafreckles
47.14
- ekhalilJun 16, 2019MasterThen you don’t seem to have double NAT.
Do you have more than one wifi network at home? Is there any way that Google devices are connected to a wifi network different than that which your phone is connected to?
Are you using the Guest network for anything other than using it for guests?- yayafrecklesJun 17, 2019Aspirant
I have a main network and a guest network. I tried connecting it to either one, but the Hub won't connect to either of them. I made sure to connect it to what my phone was connected to at the moment. The guest network has no connections on it. Its super frustrating. I dont know if I should just return all the Google hub and the 2 mini's or what. I don't understand why Orbi won't allow the connection.
- ekhalilJun 17, 2019MasterWhen do you see the issue during the attach procedure?
Do you see the Google Home hub after being factory reset? At what point after that does the problem appear?
