yayafreckles
Jun 16, 2019Aspirant
Google Home Hub connectivity to Orbi RBR40 Access Point
We have an Orbi RBR40 mesh system as an Access Point through our Verizon Gateway Router. We purchased a Google Home Hub (now called a Google Nest Hub) and cannot even set up the Hub as it refuses to ...
- Jun 17, 2019You should only select the network which you phone is connected to.
There can be some conflicting information stored in your nest hub. Please try to factory reset the nest hub and try again.
yayafreckles
47.14
ekhalil
Jun 16, 2019Master
Then you don’t seem to have double NAT.
Do you have more than one wifi network at home? Is there any way that Google devices are connected to a wifi network different than that which your phone is connected to?
Are you using the Guest network for anything other than using it for guests?
