yayafreckles
Jun 15, 2019Aspirant
Google Home Hub connectivity to Orbi RBR40 Access Point
We have an Orbi RBR40 mesh system as an Access Point through our Verizon Gateway Router. We purchased a Google Home Hub (now called a Google Nest Hub) and cannot even set up the Hub as it refuses to ...
- Jun 17, 2019You should only select the network which you phone is connected to.
There can be some conflicting information stored in your nest hub. Please try to factory reset the nest hub and try again.
ekhalil
Jun 16, 2019Master
Then you don’t seem to have double NAT.
Do you have more than one wifi network at home? Is there any way that Google devices are connected to a wifi network different than that which your phone is connected to?
Are you using the Guest network for anything other than using it for guests?
yayafreckles
Jun 16, 2019Aspirant
I have a main network and a guest network. I tried connecting it to either one, but the Hub won't connect to either of them. I made sure to connect it to what my phone was connected to at the moment. The guest network has no connections on it. Its super frustrating. I dont know if I should just return all the Google hub and the 2 mini's or what. I don't understand why Orbi won't allow the connection.
- ekhalilJun 17, 2019MasterWhen do you see the issue during the attach procedure?
Do you see the Google Home hub after being factory reset? At what point after that does the problem appear? - yayafrecklesJun 17, 2019AspirantWe just purchased the hub, so when first turning it on and attempting to set it up. It gets to the point where It tells me to download the Google Home app and connect it to WiFi. Once I try, the app
Indicates connected on my iPhone, but the hub just stays in “connecting mode” and never connects, then my phone gives me the errors I noted in the original post. - ekhalilJun 17, 2019MasterSo you reached to the stage where you have been asked to choose your wifi network, you chose the correct network and then that failed?
- yayafrecklesJun 17, 2019AspirantYes. And I have tried connecting to both my main and guest network and I get the same error both ways.
- ekhalilJun 17, 2019MasterYou should only select the network which you phone is connected to.
There can be some conflicting information stored in your nest hub. Please try to factory reset the nest hub and try again. - yayafrecklesJun 17, 2019Aspirant
IT WORKED!!!!! It accepted my Wifi and allowed me to set up the Hub. Thank you so much for assiting me over the last few days! Now hopefully the google minis will connect just fine too!
