yayafreckles
Jun 16, 2019Aspirant
Google Home Hub connectivity to Orbi RBR40 Access Point
We have an Orbi RBR40 mesh system as an Access Point through our Verizon Gateway Router. We purchased a Google Home Hub (now called a Google Nest Hub) and cannot even set up the Hub as it refuses to ...
- Jun 17, 2019You should only select the network which you phone is connected to.
There can be some conflicting information stored in your nest hub. Please try to factory reset the nest hub and try again.
yayafreckles
Jun 17, 2019Aspirant
We just purchased the hub, so when first turning it on and attempting to set it up. It gets to the point where It tells me to download the Google Home app and connect it to WiFi. Once I try, the app
Indicates connected on my iPhone, but the hub just stays in “connecting mode” and never connects, then my phone gives me the errors I noted in the original post.
ekhalil
Jun 17, 2019Master
So you reached to the stage where you have been asked to choose your wifi network, you chose the correct network and then that failed?
- yayafrecklesJun 17, 2019AspirantYes. And I have tried connecting to both my main and guest network and I get the same error both ways.
- ekhalilJun 17, 2019MasterYou should only select the network which you phone is connected to.
There can be some conflicting information stored in your nest hub. Please try to factory reset the nest hub and try again. - yayafrecklesJun 17, 2019Aspirant
IT WORKED!!!!! It accepted my Wifi and allowed me to set up the Hub. Thank you so much for assiting me over the last few days! Now hopefully the google minis will connect just fine too!
