ms13
Apr 13, 2020Initiate
Google Meet (audio / video)
So with the situation and experiencing COVID lockdown, I really need Google Meet as an option to video chat and keep in touch with coworkers ... my setup is Orbi RBR40, issue is that I dont see the option to white list an IP range NOR do I see option to port forward range of ports as a generic option (it forces to pick an internal IP only). where do i configure?
Any help would be appreciated! Thanks in Advance
| Hardware Version | RBR40 | Firmware Version | V2.3.5.32 | GUI Language Version | V1.0.0.360 | Operation Mode | Router
https://support.google.com/a/answer/7582935?hl=en
https://support.google.com/a/answer/1279090?hl=en&ref_topic=7582344
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Built in router here by chance?
Log ino the RBRs web page at 192.168.1.1 and check under Advanded Tab/Advanced Settings for Port Forwarding/Triggering options. If you use these, disable uPnP.
- ms13Initiate
my modem is http://www.hitron-americas.com/product/cda3/ from Acanac, it's strictly a pass through no router function.
yes, i have gone onto the port triggering / forward ... the program is that if i choose the range of ports ie. want to open range of ports
19302 to 19306 ... then i MUST specify a single IP on my network, ... this is no good since any device my need 'google meet'
also if i want to open the ports to entire network, then i have to do it for every single port .... a pain in the rear, ... i know it's only
a few ports, but it's the concept, i must be missing where to open ... range AND to entire network
is this a limitation to orbi ?
Try Port Triggering instead of Port Fowarding.
