CharlieB23
Jan 09, 2020Aspirant
Got disconnected often
Hi, how are you? Please help me on this. My situation: Cable modem from my ISP (with wifi desactivated both 2.4 and 5ghz), connected to the Orbi Router RBK20 via ethernet. Orbi in AP mode... I c...
- Jan 27, 2020
If it doesn't have bridge mode then it may not be supporting or have a built in router. You'll be fine for now.
Be sure to ask the ISP to ensure that you don't have a ONT with a built in router when the cross you to Fiber. Just need WAN side IP addressing up to the RBR is all.
Please mark your thread as solved if things are working better.
Blanca_O
Jan 26, 2020NETGEAR Employee Retired
Hi CharlieB23
Welcome to NETGEAR Community!
Please reset your router back to factory default settings. Follow the setup wizard and take note all security information for safe keeping. The links below may help out:
How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/31486/
How do I set up my Orbi router and satellite?
https://kb.netgear.com/31017/
Blanca
Community Team
