CharlieB23
Jan 09, 2020Aspirant
Got disconnected often
Hi, how are you? Please help me on this. My situation: Cable modem from my ISP (with wifi desactivated both 2.4 and 5ghz), connected to the Orbi Router RBK20 via ethernet. Orbi in AP mode... I c...
- Jan 27, 2020
If it doesn't have bridge mode then it may not be supporting or have a built in router. You'll be fine for now.
Be sure to ask the ISP to ensure that you don't have a ONT with a built in router when the cross you to Fiber. Just need WAN side IP addressing up to the RBR is all.
Please mark your thread as solved if things are working better.
Jan 27, 2020Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Be sure to use a web browser to access the RBRs web page. IE11, Firefox or Opera.
Be sure to clear ALL browser caches before entering the RBRs web page.
CharlieB23 wrote:Hi, how are you?
Cable modem from my ISP (with wifi desactivated both 2.4 and 5ghz), connected to the Orbi Router RBK20 via ethernet. Orbi in AP mode... I can see the App working in the Ipad and using chrome at OrbiLogin... In my dashboard, everything is green expect guest network which is yellow. But I don't want it, I don't care. If I intend to enable guest network, I get this error:
"WPS process is in progress, please apply the changes later." ... what is that?
I have this problem. Often, i'm disconnected from the wifi and I can't acces at the OrbiLogin no more...
Every time that I'm trying to use the app, it crashes the internet, I get disconnected from the OrbiLogin.
If I use only the Orbilogin (to test that everything it's working), I'm fine for a while, then some devices are connncted to the wifi but with no internet, sometimes they get disconnected also.
It looks like that only with my Imac, with no wifi, just ethernet connected to the Orbi router, the internet doens't drop
What Can it be? Some settings recommended on my router? I have this modem http://www.ubeeinteractive.com/?product=ubc1310
In the worst case scenario, reset settings and start from scratch, but I won't prefer that not.
I thought that having this my wifi system was flying LOL .. I'm kind of frustrated, nut i'm optimist to resolve it soon.
Looking forward for your help,
Have a great day
- CharlieB23Jan 27, 2020Aspirant
Hi,
Thank you for your help. At the end, restoring all factory settings, a firmware issue, and disabled a VPN app (that maybe was cusing the trouble connecting), I finally was able to set it up, 100% well functionally working now.
The weird thing is that It's working well in router mode, but I didn't put my ISP modem on bridge mode. How can this be ossible?
Thanks again your help.
D.
- FURRYe38Jan 27, 2020Guru - Experienced User
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- CharlieB23Jan 27, 2020Aspirant
Hi,
Thnaks for your reply. My modem doesn't have the bridge mode feature, I check it already. And I'm honestly happier with the full Router mode fetaures, instead of AP mode, which has much less features. And it's working fine so far.
I disables all the advanced network settings, including the Daisy Chain. And it never drops down the conenction, so far.
In the next weeks, my ISP will switch the cable to fiber optic, which it will be, I guess, a huge difference.
