CharlieB23
Jan 09, 2020Aspirant
Got disconnected often
Hi, how are you? Please help me on this. My situation: Cable modem from my ISP (with wifi desactivated both 2.4 and 5ghz), connected to the Orbi Router RBK20 via ethernet. Orbi in AP mode... I c...
- Jan 27, 2020
If it doesn't have bridge mode then it may not be supporting or have a built in router. You'll be fine for now.
Be sure to ask the ISP to ensure that you don't have a ONT with a built in router when the cross you to Fiber. Just need WAN side IP addressing up to the RBR is all.
Please mark your thread as solved if things are working better.
CharlieB23
Jan 27, 2020Aspirant
Hi,
Thnaks for your reply. My modem doesn't have the bridge mode feature, I check it already. And I'm honestly happier with the full Router mode fetaures, instead of AP mode, which has much less features. And it's working fine so far.
I disables all the advanced network settings, including the Daisy Chain. And it never drops down the conenction, so far.
In the next weeks, my ISP will switch the cable to fiber optic, which it will be, I guess, a huge difference.
Jan 27, 2020Guru - Experienced User
