jbyrd2
May 11, 2020Aspirant
Grandstream VoIP Phone not working Orbi RBR50
I've had my VOIP phone for two years with no problems and about 2 months ago, It can not reach the main host. I worked on this with IT and everything seems correct but it was not connecting. We even ...
- May 11, 2020
Give it about 2 minutes before giving up with the phone connected directly. Sometimes the modem takes a minute or two to switch over to a public IP adddress when a single PC or device is connected. Possible the phone won't support that either. Was a thought.
jbyrd2
No Armor or Circle. I will reboot everything and report back. The last time I tried to plug it diredctly into the SB8200, it never connected like it use to.
May 11, 2020Guru - Experienced User
- jbyrd2May 11, 2020Aspirant
That was good advice to leave it connected. It reeach the host and connected. I then shutdown the system and rebooted it. It now is conencted . I have like 32 conencted deviced so when the internet goes down I start getting emails and alerts. Thanks again!
- FURRYe38May 12, 2020Guru - Experienced User
Hopefully it will keep working for you.
Enjoy. :smileywink:
