RASHID007
Jan 12, 2018Guide
Great Forum (Read Threads) Orbi with Gigabit Fiber Wifi Speed Tested
Good day all, great forum here with lots of helpful threads that I read. As a result of those threads and great posts from more senior members I've done some troubleshooting/testing BEFORE posting t...
RASHID007
Jan 14, 2018Guide
Please somebody help. I’ve exhausted every idea I can google. I understand 20Mhz 2.4 May not put at 200mbps but I’m getting less than half of that. No real competing WiFi networks (scanned to confirm) big house on big lot so neighbors not an issue).
And 5Ghz getting 250 to 300mbps vs should be closer to 500mbps. Also iperf test shows internal to network 5Ghz WiFi is capable of almost 700mbps.
RASHID007
Jan 15, 2018Guide
No replies? Someone please help.
- guzzijasonJan 15, 2018Apprentice
Have you tried removing the Orbi router from the equation and do a series of speed tests while directly connected to your ISP gateway/router? Your iPerf test seems to indicate that your WiFI is fine, so it's possible that your ISP (or some other hop) beteween you and the external speed test servers is the bottleneck.
