alokeprasad's avatar
Mar 07, 2021
great opportunity to buy RBK53
I apologize if this is in violation of the rules here.  And fully understand if you remove this post.   Woot has a great (very limited time) price on RBK53 (router plus 2 satellites of AC3000), new...
  • woodzy68's avatar
    woodzy68
    Mar 07, 2021
    Exactly what i did... worked fine.
    Just plug in one of the new satellites and then run the "add satellite" from the settings menu in your current Orbi App...
    I then sold the remaining router and satellite and they had no problems.
    I'm not even sure they came paired; distant memory of setting up my original Orbi was that it went through the "add satellite" process.
