Gabe777
Sep 19, 2019Tutor
Gryphon wifi router connected to orbi satellite slow.
Hi, My orbi router is connected to my AT&T wifi gateway (fiber 300 Mb) with 2 additional orbi satellites around the house. I was unable to update apps on mobile devices so turned off wifi on AT&T...
Sep 19, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Gabe777 wrote:Hi,
My orbi router is connected to my AT&T wifi gateway (fiber 300 Mb) with 2 additional orbi satellites around the house. I was unable to update apps on mobile devices so turned off wifi on AT&T wifi gateway and changed my orbi to an access point. Afterwards, I can update and download apps now on wireless devices.
My question: I have a Gryphon wifi router that I use for parental control/monitoring hooked to an orbi satellite with ethernet cable broadcasting a different SSID than the orbi. The wifi speed test for Gyphon wifi router is much slower than orbi wif speedtest. Why is this happening?
Any advice or solutions to slow wifi on my Gryphon router would be greatly appreciated. Thank you!
- Gabe777Sep 19, 2019TutorOrbi has already been configured to AP mode using your suggestion #3. Any ideas for fixing the slow Gryphon router on 2nd floor which is connected to orbi satellite? Thanks!
