Gabe777
Sep 19, 2019Tutor
Gryphon wifi router connected to orbi satellite slow.
Hi, My orbi router is connected to my AT&T wifi gateway (fiber 300 Mb) with 2 additional orbi satellites around the house. I was unable to update apps on mobile devices so turned off wifi on AT&T...
Gabe777
Sep 19, 2019Tutor
Thank you very much, Plemans.
1. So with the WiFi disabled on Gryphon, I connect the Gryphon with Ethernet cable to the passthrough ATT modem, correct?
2. Just to confirm, I then connect the Orbi router (in AP mode) to the Gryphon with Ethernet cable?
3. Lastly, with the orbi satellites around the house broadcasting WiFi, I will be able to login to Orbi’s SSID and still use Gryphon’s app for parents controls.
Your help is much appreciated.
Sep 19, 2019Guru - Experienced User
That sounds right with the way you've set it up.
this will allow the att device to act as gateway, gryphone as router/parental controls, and orbi as wifi.
