Meob1
Oct 22, 2021Aspirant
GS108Tv3 detected as Connected Satellite
how can this be removed from Orbi UI ?
Oct 22, 2021Guru - Experienced User
What model Orbi do you have?
Looks like Orbi AX? If so, Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
IF you have a Switch in between the RBR and RBS, then the RBR will report this as a connection point with the RBS. By design.
Thank you
How many RBS do you have connected to the RBR?
