Rumplestiltskin
Sep 26, 2017Aspirant
Guest Network - Static Route?
Hi, I have one last question before I take the plunge.... Is it possible to allow the guest network access to just one IP address on the main network, maybe by using a static route? Thanks ...
DarrenM
Sep 28, 2017Sr. NETGEAR Moderator
Hello Rumplestiltskin
In the orbi settings its all or none when allowing the guest network to see the main network.
DarrenM
- RumplestiltskinOct 04, 2017AspirantThanks.
If the Orbi is in AP mode, is it possible for the router that it's connected to to differentiate between normal wifi and guest wifi, i.e, is it on its own subnet or tagged in some way?
Thanks
Rumple
