l11nad's avatar
l11nad
Follower
Feb 27, 2020
Guest Network able to open RDP sessions on network
Hi There
We've purchased and setup an RBR50 ad RBS50 to add a mesh  into our small office network, we had some dead spots with our previous equipment and this has resolved these issues,
The RBR50 is connect directly into our wired nework and configured as an Access Point (AP) as is the RBS50, the wired back haul is working correctly, we're able to wirelessly connect to our office network, browse servers and NAS, printers, RDP sessions etc.
Having set the guest network up, with "Allow guests to see each other and access my local netowrk" turned off, all seems well. Guests have reliable internet connections and are unable to browse our network....
However, guests can start RDP sessions onto our servers. Obviously these are account and password protected so we are somewhat protected, though this leaves me unsettled that this could happen, it seems that the guest network is not fully disconnected.
Firmware is current v2.3.5.30, and the firmware update is saying there are no further updates, however i can manually download v2.5.1.8.
Is this a problem that has been seen before and has been cleared up in this later firmware?
it seems like a blindingly obvious secruity flaw
  • l11nad, I was concerned when I saw your question posted here.  So I duplicated your testing.  I bound my laptop to my guest network and could not access any local resources, including using Remote Desktop.  I could only use RDP to my desktop from my laptop when on my primary network.  When on the guest network, the hostname is not resolvable for my desktop, so I used the 192.168.1.X IP assigned to it and it still could not open an RDP connection.  Are you sure that you do not have RDP tunneled through the firewall to the internet in your router settings to allow this?  i.e. you allow RDP to mypc.mydomain.com from the internet?  I used firmware v2.5.1.8 on my RBR50 and RBS50 satellites for my testing, so perhaps this is an issue with your v2.3.5.30 firmware if you don't allow internet RDP access.
    • CrimpOn's avatar
      CrimpOn
      I did a similar test, opening Orbi Guest access and not allowing guest devices to see the primary network.  Connected my phone, and it behaves as expected.  No access.  However....
      • I cannot test in AP mode (having only a modem, and I don't want to go fetch an old router to stick in the middle of all this).
      • My phone did get an IP address in the primary subnet.  (This is one of the ways that Orbi WiFi 6 appears to be different from my Orbi WiFi 5.  I hear that the guest network on Orbi WiFi 6 is in a different subnet.)
        So, the Orbi is not going to let a guest device access the primary network, but what about the router that Orbi is connected to?
        @I11nad said "Guests have reliable internet connections and are unable to browse our network....."
        I wonder how this works?  Shouldn't the primary router just see packets from a subnet going to IP
        's on the same subnet?
      This is very confusing.
      • How was this "unable to browse" tested?
        (ping?  network scanner like Fing?  trying to use a printer?)
      • Does AP mode somehow recognize IP's from the guest network and shut them out?
        Way Cool.  Pretty slick programming for an "access point".
      • Or, does RDP actually go out to the internet and then back into the network?
      • tomschmidt's avatar
        tomschmidt
        Virtuoso
        Thanks CrimpOn for noting that l11nad was using AP mode, not Router mode on his Orbi.  My Orbi is in router mode, and I do not want to break things either by adding a different router between my modem and Orbi and putting the Orbi in AP mode.
        l11nad, I suspect your issue is due to your primary router allowing the access, as it has no means of distinguishing the Orbi guest and primary networks.  For this to work properly, you need to remove your primary router and let the Orbi be in router mode rather than AP mode.  You have a double NAT situation which is not recommended.  Search for "double NAT" on the community forums or google for more information about it.
