Josh-Teksperts's avatar
Mar 13, 2018
Guest Network Default Splashscreen takes over two minutes to load on iOS devices (SRR60)
We have recently purchased and set up an Orbi Pro Business WiFi+satellite system on a FiOS internet connection.
Connection speeds are fantastic (around 85mps up and down).
We have an admin network, an employee network and a guest network.
The guest network uses the default terms of service splashscreen, has a password set, and allows for an hour of access.
The trouble is that all tested iOS devices (even the newest ones including iPhone X) take the better part of 2 minutes to load the sign-in splash screen and then perhaps another 2 minutes to acknowledge the sign in. My mid-teir Android phone takes all of about 5 seconds to show the screen and log into the same network.
One suggestion I tried was choosing to disable the channel bonding option, but that has not seemed to help.
I've restarted the system several times.
It's running current firmware.
And I've reset up the system as well.
The issue persists...but only with iOS devices.
Has anyone else had this issue? Did you find a workaround?
