bugzpodder
Dec 27, 2021Aspirant
guest network DNS issues
RBR750 guest network DNS issues My main network is fine but my guest network constantly have connection issues. When i go visit some site it could not resolve the dns and dies. Everything...
- Dec 29, 2021
Just solved this issue by switching to Archer AX11000
CrimpOn
Dec 27, 2021Guru - Experienced User
"connection issues" is a bit ambiguous (could have different meanings). It would help to have more details about the problem.
- The device(s) do not lose the WiFi connection to the Orbi, correct?
- Does the device enable you to test the DNS function directly?
i.e. on a Windows computer, open a command window and attempt to 'ping' someplace, such as:
ping ford.com
or
ping dns.googe.com
Does the URL get translated to an IP address?
bugzpodder
Dec 28, 2021Aspirant
URL typed into browser's address bar cannot be DNS resolved.
- CrimpOnDec 28, 2021Guru - Experienced User
only some URL's and only some of the time?
Does this happen to every device that connects to the Guest WiFi, or only to certain devices?
- bugzpodderDec 28, 2021Aspirant
All URLs cannot resolve. I haven't tried with other devices but if a macbook has issues with only this network (and not the main network) then it is clearly the Orbi's issue.
Any ping command gets stuck. It happens several times a day on the guest network. - bugzpodderDec 29, 2021Aspirant
