Orbi
Dec 19, 2016Star
Guest network does not extend thru satellites
It seems the guest network does not extend thru the satellites. From the satellites you don't even get the guest signal.
peteytesting
Dec 20, 2016Hero
you must be doing something wrong as if you get something like inssider on your comp and start it up you will initially see 6 orbi transmissions , if you then enable the guest wifi you see an additional 6 guest network transmissions
if you sats are too far away they may not be communicating with the router but then would have the magenta light showing
- OrbiDec 20, 2016Star
Before you start telling people that they are doing something wrong perhaps you should know what you are talking about.
I'm on firmware V1.4.0.18
I have 2 satellites(rbs50) approx 25 feet from the main router(rbk50).When I check the wifi signal, at the router I see full bars of both main SSID and Guest SSIDWhen I walk 20 feet beyond the satellite away from router, I get 0 bar guest and FULL bars main ssid.(me)---(rbs50)---(rbk50)---(rbs50)This tells me that the Guest network is not working thru the satellite.Also when you log into the satellite, you will only see information about main SSID and not the guest network.Perhaps you dont know what you are talking about.- peteytestingDec 20, 2016Hero
nah , only been on orbi for 6 months
again get a propper wifi analyzer and see if you have 6 normal transmissions and 6 guest transmissions showing , if you dont the sats not working , if you do something else is wrong
the gest wifi transmission power and channels should match the main transmission power and channels for the main orbi
I'm using wifi analyzer on google play, it pretty much confirms my conclusions that the guest network is not extending thru the satellite. BTW, you're experience is equal to mine with Orbi Guest networks, since it was just recently release so please stop telling people they are doing something wrong when you dont know what you're talking about.
