radracer
Dec 30, 2018Follower
Guest Network "guests to see each other and access my local network" option Not working
I have the RBR40, V2.2.1.210, and I have Guest Network enabled, but I do not have the checkbox set for "Allow guests to see each other and access my local network". However, when I connect to the gue...
Dec 31, 2018Guru - Experienced User
How was the FW updated? Via Auto Update? I would try a factory reset on the Base unit then set up from scratch. Check the Guest Network accessbility features.
