whittle
Jun 18, 2018Guide
Guest network in AP Mode?
I'm thinking about putting a router in front of my RBK50 and running the Orbi system in Access Point mode. Do you lose access to the Guest Network feature in AP mode?
Thanks much.
whittl...
Jun 18, 2018Guru - Experienced User
I believe so since the WAN port become a LAN port and the separation beteen WAN and LAN is disabled which Guest Network is dependent upon the WAN side being used.
