whittle
Jun 18, 2018Guide
Guest network in AP Mode?
I'm thinking about putting a router in front of my RBK50 and running the Orbi system in Access Point mode. Do you lose access to the Guest Network feature in AP mode?
Thanks much.
whittl...
Mozez
Jun 18, 2018Guide
Thanks much.
whittle
Hi Whittle,
Yes you can. That is exactly how I have mine setup right now. My FIOS router is handling all the DHCP, DNS, firewall stuff and my ORBI is running in AP mode only. You can enable the GUEST wifi on the ORBI without any issues. You do have to use the web interface (orbilogin.com) to turn on the guest network. You can also use the android app (netgear genie) to turn the guest network on/off. The option to do so on the IOS app is not available when you turn on AP mode, for whatever reason.
Moses
- whittleJun 18, 2018Guide
Thanks very much Moses. I think I will give it a go. Just for reference, what Orbi firmware are you running? -whittle
- MozezJun 18, 2018Guide
Hi Whittle,
My ORBI router is currently on 2.1.4.10.
Moses
Moses,
Another question if I am not overstaying my welcome...
Do you know if the LAN ports on your Orbi router and Orbi satelites are active in your configuration? Are they basically acting as switch ports for your internal network?
-whittle
