bd81
Jan 03, 2019Tutor
Guest network in AP Mode?
I started experiencing some glitches so I decided to use a another router and try Orbi setup in AP mode. I got it up and running but the guest network is visible but not functional. I made sure everyt...
bd81
Jan 03, 2019Tutor
Strange thing happened, after about 30 min the guest network simply disappeared. Another instance of Orbi being Orbi LOL. So I guess all is good for now. Thanks for your reply.
Jan 03, 2019Guru - Experienced User
Seen others mention during the reboot process, GN is seen then disappears.
You should be ok.
