VFMass
May 17, 2019Aspirant
Guest Network not broadcasting through Satellite
Both Satellite and Router are up-to-date with hte current firmware. what's odd is that the satellite (which is backhauled through ethernet) is showing offline in the app (but connected directly shows...
- May 18, 2019
VFMass wrote:
V2.3.1.60I think this is one of the issues introduced in 2.3.1.60. I think that something is wrong in the Satellite software. Please try the following:
- Power off the Satellite. Keep the Ethernet backhaul connected.
- Go to "Attached Devices" in the web GUI, and click on "Remove" or "Forget" device for the Satellite that you powered off.
- Now power on the Satellite and then use a paper clip to factory reset it.
- When the Satellite comes up press the Sync button on the Router and then on the Satellite to connect the Satellite to the Router
- That's it, when the Satellite comes up things will continue working as they should!
May 17, 2019Guru - Experienced User
What FW version is currently loaded on the system?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
VFMass
It's in my office building which includes thick walls—which is why I had the satellite connected via ethernet. Is there any reason for the guest to stop working when the ethernet is connected?
- FURRYe38May 17, 2019Guru - Experienced User
