VFMass
May 17, 2019Aspirant
Guest Network not broadcasting through Satellite
Both Satellite and Router are up-to-date with hte current firmware. what's odd is that the satellite (which is backhauled through ethernet) is showing offline in the app (but connected directly shows...
- May 18, 2019
VFMass wrote:
V2.3.1.60I think this is one of the issues introduced in 2.3.1.60. I think that something is wrong in the Satellite software. Please try the following:
- Power off the Satellite. Keep the Ethernet backhaul connected.
- Go to "Attached Devices" in the web GUI, and click on "Remove" or "Forget" device for the Satellite that you powered off.
- Now power on the Satellite and then use a paper clip to factory reset it.
- When the Satellite comes up press the Sync button on the Router and then on the Satellite to connect the Satellite to the Router
- That's it, when the Satellite comes up things will continue working as they should!
VFMass
It's in my office building which includes thick walls—which is why I had the satellite connected via ethernet. Is there any reason for the guest to stop working when the ethernet is connected?
May 17, 2019Guru - Experienced User
What FW version is currently loaded on the system?
- VFMassMay 17, 2019AspirantV2.3.1.60
- FURRYe38May 17, 2019Guru - Experienced User
So you don't get guest network at the RBS when ethernet connected? I presume guest network is running at the RBR when the RBS is ethernet connected?
- ekhalilMay 18, 2019Master
- VFMassMay 20, 2019Aspirant
I am surprised that there is such a significant bug that hasn't been resolved yet. Thank you for this.
