hphan1229
Feb 13, 2020Aspirant
Guest network not working on the RBR50 + RBW30 mesh system and 2.4Ghz network issue.
I had the Orbi mesh system that includes the RBR50 router and 2 satellite RBW30 about 2 months. I've upgraded to the firmware version 2.5.1.8. I have couple IOT devices (Nest Yale X Lock, Nest ther...
Feb 14, 2020Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- hphan1229Apr 17, 2020Aspirant
FURRYe38 wrote:What is the Mfr and model# of the ISP modem the NG router is connected too?
SURFBoard SB6183
What is the size of your home? Sq Ft?3300 sqft
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router30-40 ft
Any Wifi Neighbors near by? If so, how many?I've tried channel 1, 6, and 11 on 2.4Ghz and 48 on 5ghz
I can detect about 6 other wifi SIDs from the neighbors.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Done this but no helps.
Not yet.
- FURRYe38Apr 17, 2020Guru - Experienced User
Try a factory reset, I believe this corrected another users problem with Guest Network not working on theres a while back.
SURFBoard SB6183
Not yet.
