hphan1229
Feb 13, 2020Aspirant
Guest network not working on the RBR50 + RBW30 mesh system and 2.4Ghz network issue.
I had the Orbi mesh system that includes the RBR50 router and 2 satellite RBW30 about 2 months. I've upgraded to the firmware version 2.5.1.8. I have couple IOT devices (Nest Yale X Lock, Nest ther...
pravinvekaria
Feb 29, 2020Aspirant
Regarding the Guest Network, i have the same issue. I have multiple models of Satellites, the one that is causing the issue for Guest WiFi is the RBW30, disconnect that from the power and your guest network will start working! With it connected and if your device has roamed onto that Satelitte then your guest will get an IP address and everything will look fine but you wont be able to get any Internet Access or ping any internal (which is expected on guest) or external (which should work) IP addresses.
hphan1229
Apr 17, 2020Aspirant
I'll try to see if this works.
