hphan1229
Feb 13, 2020Aspirant
Guest network not working on the RBR50 + RBW30 mesh system and 2.4Ghz network issue.
I had the Orbi mesh system that includes the RBR50 router and 2 satellite RBW30 about 2 months. I've upgraded to the firmware version 2.5.1.8. I have couple IOT devices (Nest Yale X Lock, Nest ther...
hphan1229
Apr 17, 2020Aspirant
FURRYe38 wrote:What is the Mfr and model# of the ISP modem the NG router is connected too?
SURFBoard SB6183
What is the size of your home? Sq Ft?3300 sqft
30-40 ft
I've tried channel 1, 6, and 11 on 2.4Ghz and 48 on 5ghz
I can detect about 6 other wifi SIDs from the neighbors.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Done this but no helps.
Not yet.
Apr 17, 2020Guru - Experienced User
Try a factory reset, I believe this corrected another users problem with Guest Network not working on theres a while back.
SURFBoard SB6183
30-40 ft
Not yet.
