alokeprasad's avatar
Jul 10, 2024
Guest network slower than regular network?
I'm finding speedtest and performance of my iPhone 12 Max slower on the guest network than regular network.    This is anywhere in the house, even in the same room as the router.  The two satellite...
  • CrimpOn's avatar
    CrimpOn
    Jul 13, 2024
    Thanks for reporting actual numbers (although the "regular" values may be reversed [up/down]).
    Testing on the same RBR50 router with a WiFi connection to a Samsung Galaxy tablet, I got these readings from the Ookla Speed Test web site:
    Network Down Up
    Guest   333  11.9
            326  10.2
            342  11.1
    Primary 337  12.0
            369  11.7
            372  11.0
    Guest   369  11.7
            369  11.5
            366  11.9
    I am on Spectrum Cable (upload speeds are tiny on cable compared to download speeds).
    A computer wired to the router reported 354 down/11.5 up.
    Thus, my experience is that the Guest WiFi network performs "about the same" as the primary WiFi network.
    This original Orbi is a WiFi5 system, with a maximum theoretical connection rate on 5G WiFi of 866Mbit.  In actual use, getting 500Mbit is very good.
    Are there any other WiFi devices that can be used to compare speeds on the primary vs. Guest WiFi networks?
