alokeprasad
Jul 10, 2024Mentor
Guest network slower than regular network?
I'm finding speedtest and performance of my iPhone 12 Max slower on the guest network than regular network. This is anywhere in the house, even in the same room as the router. The two satellite...
- Jul 13, 2024
Thanks for reporting actual numbers (although the "regular" values may be reversed [up/down]).
Testing on the same RBR50 router with a WiFi connection to a Samsung Galaxy tablet, I got these readings from the Ookla Speed Test web site:
Network Down Up
Guest 333 11.9
326 10.2
342 11.1
Primary 337 12.0
369 11.7
372 11.0
Guest 369 11.7
369 11.5
366 11.9
I am on Spectrum Cable (upload speeds are tiny on cable compared to download speeds).
A computer wired to the router reported 354 down/11.5 up.
Thus, my experience is that the Guest WiFi network performs "about the same" as the primary WiFi network.
This original Orbi is a WiFi5 system, with a maximum theoretical connection rate on 5G WiFi of 866Mbit. In actual use, getting 500Mbit is very good.
Are there any other WiFi devices that can be used to compare speeds on the primary vs. Guest WiFi networks?
CrimpOn
Jul 11, 2024Guru - Experienced User
It is not obvious (to me) why that would be the case. Can you share actual numbers?
alokeprasad
Jul 12, 2024Mentor
It is not always this consistent (sometimes the guest network performance is fine..)
Example just now:
Guest: 31.8 Mbps down; 21.1 Mbps up; Ping 16 ms
Regular: 575 Mbps up; 23.3 Mbps down; Ping 15 ms.
Wired (through the Orbi web interface on a Mac): 578 Mbps down; 24.27 Mbps up
The wireless tests are on a iPhone 12 Pro Max in the same room as the router.
