rp17
Feb 09, 2019Guide
Guest network xbox live
I have an Orbi RBR40 router with 2 satellites. I have a tenant that uses the guest network that has an Xbox. Xbox live will not work property on the guest network saying there is a problem with toredo...
Chuck_M
Feb 10, 2019Mentor
Is IP6 enabled? Try disabiling it if your ISP doesnt support./
