Darrrio's avatar
Darrrio
Guest network
Hi I couldn't find the Guest Network function in my RBR50 menu. I saw people complainig for the guest network being disruptive on ORBI systems. Does anybody knows anything about it? Are they planning...
  • aaz's avatar
    Oct 02, 2017
    What firmware are your Orbi's on? As far as I know version 2.0.x.x supports the guest network just fine. The complaints being that you cannot turn it off and on without disrupting the main network as the router seems to reboot when you do that.
