Darrrio
Oct 02, 2017Aspirant
Guest network
Hi I couldn't find the Guest Network function in my RBR50 menu. I saw people complainig for the guest network being disruptive on ORBI systems. Does anybody knows anything about it? Are they planning...
- Oct 02, 2017
What firmware are your Orbi's on? As far as I know version 2.0.x.x supports the guest network just fine. The complaints being that you cannot turn it off and on without disrupting the main network as the router seems to reboot when you do that.
aaz
Oct 02, 2017Virtuoso
Darrrio
Hi AAZ,
I installed the latest firmware upgrade manually and everything works just fine now. I don't actually need to switch on and off the guest network, therefore the forced disruptive system reload issue doesn't affect me.
Thank you for your support.
Dario
Dario
