dchbbc
Feb 26, 2019Apprentice
Guest network
I have a RBR40 with 3 satellites. I'm not sure why this model doesn't show up as a choice. I made a guest network. I have it disabled but I want to delete it completely. I can't find how to do this. ...
Feb 26, 2019Guru - Experienced User
You need to log in to the routers web page using a PC or laptop and a web browser to disable Guest Network. SHould be under the Basic Tab or Advanced Tab.
dchbbc
Hi. Thanks. I did that already and there is no disable, at least on mine. I tried to delete the name and password but it won't save without them. I guess I'll just have to leave it.
- FURRYe38Feb 26, 2019Guru - Experienced User
What browser are you using? There should be a check mark to enable or disable Guest Network.
You can do a factory reset ON the RBR and setup from scratch. Guest Network is disabled by default if I remember correctly.
- dchbbcFeb 26, 2019Apprentice
I'm on Edge Windows 10. I can try on Chrome or on my iPad. Too much work to reset everything and put all of the custom names back. Thanks for the help though
Ok, there should be a disable and enable check box. Look for this. Try with a different browser.
Good Luck.
