dchbbc
Feb 26, 2019Apprentice
guest network
I have a RBR40 with 3 satellites. I'm not sure why this model doesn't show up as a choice. I made a guest network. I have it disabled but I want to delete it completely. I can't find how to do this. ...
CrimpOn
Feb 26, 2019Guru - Experienced User
Sorry. I know of no way to "eliminate" the Guest network from Orbi's setup pages. Generally, options can be disabled, but not made to "go away" from the Administrative controls. When Guest network is disabled, the Orbi not accept connections. As far as devices are concerned, it doesn't exist. As an example, when I decide to put my Orbi in AP mode and not provide IP addresses through DHCP, all of the DHCP options remain in the web interface. I just cannot set them to anything, and as far as my network is concerned, they are "gone."
Chuck_M
Feb 26, 2019Mentor
The guest network doesn't electronically exist if it has been disabled.
Unchecking the boxes in the web gui (http://192.168.1.1/index.htm) will eliminate the existence of the guest network.
If you want to delete the SSID that it used, just put spaces in the field that says Guest Wireless Network name. You have to put something in the password field as it wont accept blanks.
See below.
- ekhalilFeb 27, 2019Master
You can also use the Orbi phone app to disable the Guest Network. Go to Guest Network on the app:
